Автор Тема: LV-256  (Прочитано 396 раз)
LV-256
« : 21 Октября 2020, 00:02:41 »
Subject THE CI SLOT COVER IS TIGHT
Model LC-37X20E, LC-37X20S, LC-37X20RU
LC-32X20E, LC-32X20S, LC-32X20RU
General The CI (Common Interface) slot cover fitting is tight and it is hard to remove.
Servicing If customer complains of the tight CI slot cover, please explain on how to remove the CI slot cover.
Please refer to the following errata sheets
Parts Ref. Parts code
No. Description OLD NEW Q’ty
Interchangeability
Price
code
--- Errata sheet for Europe --- TCAUHA342WJZZ 1 --- ---
--- Errata sheet for Russia --- TCAUHA343WJZZ 1 --- ---
Interchangeability
A: Completely interchangeable.
B: Interchangeable from OLD to NEW.
C: Interchangeable from NEW to OLD.
D: Not interchangeable.
Production
change
• From the middle of November 2007 production, the above mentioned errata sheets which explains on
how to remove the CI slot cover is added. (Running change)
• The hole of CI slot metal fittings will be improved in the further production.
