Автор Тема: LV-214  (Прочитано 399 раз)
LV-214
« : 20 Октября 2020, 23:45:26 »
Subject DEFECTIVE IC3002
Model LC-32RA1E, LC-32RA1RU
LC-32RD1E, LC-32RD1RU
LC-37RA1E, LC-37RA1RU
LC-37RD1E, LC-37RD1RU
LC-42RD1E, LC-42RD1RU
General A defective IC3002 was experienced in the field.
We would like to inform you about the servicing method as follows.
Phenomenon 1) The OSD flickers.
2) The backlight can not be controlled.
3) The screen freezes when operating TELETEXT.
4) The screen becomes dark continuously and unable to restore.
Cause Defective IC3002 (RH-IXB698WJN1Q) on the main unit
Servicing When the above phenomenon happened, there is a possibility that the IC3002 is defective.
Please replace the existing main unit with new one.
The replacement main unit which has a good IC3002 can be distinguished with either of the
following methods.
• Check if the lot marking of the replacement main unit is “B37”.
• Check if the date code of IC3002 (on the replacement main unit) is 6278 or later.
Main unit IC3002 on the main unit
