Автор Тема: LV-172  (Прочитано 372 раз)
LV-172
« : 20 Октября 2020, 23:38:13 »
Subject MAIN SOFTWARE UPGRADE
Model TU-65GD1E
General We upgraded the main software to version 1.02. This software version can solve the following
phenomena.
Phenomenon SOUND key does not work in the DTV mode when voice broadcasting for blind persons is
received.
Servicing In this case, please upgrade main software to the following version by using SD memory card.
For the details on how to upgrade, please refer to the service manual.
Main software version Software file for upgrading Applicable model
1.02 (E 2006/04/07 1) KD7EA102.SDC LC-65GD1E
Note:
Upgrading main software by using SD memory card does not initialize the current user settings.
If you need to initialize the current user setting, perform “INDSTRIAL INIT” in the process
adjustment mode.
Production
Change
Change from May 2006.
MODEL NAME CHANGE START SERIAL NO.
TU-65GD1E 603311423
TU-65GD1E F 603311234
TU-65GD1E I 603311162
TU-65GD1E K 601311166
TU-65GD1E R 603311191
