Автор Тема: LV-168  (Прочитано 364 раз)
LV-168
« : 20 Октября 2020, 23:36:30 »
Model LC-37AF3M, LC-37AF3H, LC-37AF3X
LC-32AF3M, LC-32AF3H, LC-32AF3X
LC-26AF3M, LC-26AF3H, LC-26AF3X
LC-37AX3M, LC-37AX3H, LC-37AX3X
LC-32AX3M, LC-32AX3H, LC-32AX3X
LC-37GA5T
General There is possibility that a defective CPLD IC (Complex Programmable logic device) has been
used in some above mentioned production sets. In order to avoid the occurrence of a trouble
caused by this defective CPLD IC, we would like to ask you to perform the following servicing
procedure.
Phenomenon When the CPLD IC breaks down, the mainly following phenomena occur.
• The power is on, but no backlight.
• Can’t power on, only standby mode.
Servicing When you receive any above mentioned sets in any case, please take the steps following the
flowchart of the next page.
Parts Model REF No.
LC-37/32/26AF3 series IC2007 (RH-IXB495WJZZQ or RH-IXB495WJN1Q)
LC-37/32AX3 series
LC-37GA5T
IC1014 (RH-IXB496WJQZQ)
IC1503 (RH-IXB497WJQZQ or RH-IXB497WJQ1Q)
