Автор Тема: LV-113  (Прочитано 348 раз)
LV-113
« : 20 Октября 2020, 22:46:07 »
Model LC-20SH1E, LC-15SH1E, LC-13SH1E
General MAIN microprocessor software has been changed to Ver.0.95 in order to correct the following
phenomena.
• Child Lock is set when “OK” is pressed without entering PIN.
• Sound Wide effect is weak.
• The Input mode is not switched to the external mode when an external signal has been inputted
via SCART before the power of the set is turned on.
Servicing If the MAIN microprocessor software upgrade is required, please upgrade it to Ver.0.95.
For the upgrade procedure, please refer to the service manual.
Main software version Software file needed
Ver.0.95 LC20SH1_PhilipsvBeta1.4_Sharpv0.95.hex
