Автор Тема: GD7-1  (Прочитано 386 раз)
GD7-1
« : 20 Октября 2020, 19:55:45 »
Please note this information for your service.
Model LC-37GD7E
Phenomenon In very few cases it is possible that the rubber pad can be conductive and the distance
between primary and secondary parts of this set could be unacceptably reduced. In extreme
case the set is not conform to the standard.
Cause The gap between the rubber pad and the metal of the chassis is too low. In worst case the
rubber pad touches the metal-chassis.
Factory action The rubber pad has been removed and a new modification has been applied (see picture 1)
