Автор Тема: FSB110033  (Прочитано 429 раз)
FSB110033
« : 20 Октября 2020, 19:53:46 »
LC-26LE320E
2. Symptom : TV did not have picture/function.
3. Cause : It was caused by Power Supply where the IC905 is shorted. Some of them found the D2
diode and F1 fuse of LCD panel also has failed.
4.Affected
production date :
Before 2011-01-25
5.Affected
serial number :
N/A
6. Cure : 1. Replace IC905 on the power board ADTVA2432SA1 on the board as below picture.
Item TPV P/N Sharp 13NC Description
IC905 056G 563185 9JR5600000212 IC RT8289GSP SOP-8
