Автор Тема: Blocked Sound Problem on MB6x (MB60, MB62)  (Прочитано 350 раз)
« : 20 Октября 2020, 11:35:29 »
LC-32LE510
LC-40LE510
LC-32SH310
LC-32SH340
LC-32D12E(A)
LC-40SH340
LC-40F22E(A)
LC-32LE140
LC-32LE240
LC-40LE240 / LC-40LS240
PRIORITY
( )S. All products
( )A. Items in Customer / Dealer stock / Service return goods
( )B. Customer stock / Units returned for Service
( )C. Sold items returned for service
( )D. Only units returned to this bulletin
( )E. Others
DATE: September 14th, 2012
PUBLISHED BY: Selçuk Uğuz - Technical Support Engineer / selcuk.uguz@vestel.com.tr
SUBJECT: Blocked Sound Problem on MB6x (MB60, MB62)
< Objective >
This service bulletin is being published to inform about a solution to the issue at subject.
< Information >
• TVs rarely would block the sound, after it worked for 2-3 hours.
• Root cause of the problem is due to the sensitivity of the audio input level of Audio IC, U168.
Therefore, component change will solve this problem, which are exist on below positions 1uF instead
of 470 nF
• Relevant problematic material positions are; C1075, C1076, C1077, C1078
• Vestel change references are;
# 2012001110 Change date: 13-September-2012
# 2012001092 Change date: 12-September-2012
• Problematic part code: 30050557 CAP SMD 470NF 6.3V K X5R (0402) RoHS
• New part code: 30050554 CAP SMD 1UF 6.3V M X5R (0402) RoHS
< Instructions >
• Dismount the capacitors –470nF– at the C1075, C1076, C1077, C1078 positions on the MB6x chassis
