Автор Тема: TRO13-007  (Прочитано 395 раз)
TRO13-007
« : 20 Октября 2020, 10:12:57 »
General We are to inform you about the changes of ORION model LE440M series with suffix 'C'
Subject
Model
Technical Report SLCD-003 in the eService for further perusal.
Marking
Note : All model are using the same tuner part on the mainboard.
A : Completely Interchangeable
B : OLD parts can be used in place of NEW parts
NEW parts cannot be used in place of OLD parts.
D : Not interchangeable
C : OLD parts cannot be used in place of NEW parts.
NEW parts can be used in place of OLD parts.
Model OLD Unit Suffix NEW Unit Suffix
LC-39LE440M LC-39LE440M (B) LC-39LE440M (C)
D
9JD1564200011
9JD1564200021
9JD0145E19001
LC-29/39/
50LE440M
Mainboard
BK
LC-24LE440M
LC-39LE440M
LC-50LE440M
~ 3095xxxxx 3105xxxxx ~
Note : Regarding the changes for model with suffix 'B' for model 29", 39", and 50" please refer to
3105xxxxx ~
LC-29LE440M ~ 3095xxxxx 3105xxxxx ~
~ 3095xxxxx
i. Mainboard change the "Silicon" Tuner because "CAN" Tuner is EOL
ii. Change of the Software version & File name for upgrade by USB memory
Model
OLD Serial Number NEW Serial Number { LE440M (C) }
Cut-off Serial Number
LC-24LE440M Mainboard 9JD1564200035 A
LC-24LE440M LC-24LE440M LC-24LE440M (C)
LC-29LE440M LC-29LE440M (B) LC-29LE440M (C)
Picture 1 : Example image of the OLD unit suffix (B) and NEW unit suffix (C)
AU
Interchangeability
9JD1564200036 BM A
LC-50LE440M LC-50LE440M (B) LC-50LE440M (C)
