Автор Тема: PLDC-Z901A состав  (Прочитано 116 раз)
PLDC-Z901A состав
« : 01 Октября 2020, 05:05:47 »
F100   4A
F101   3,15A
F102   1A
F103   1A
IC101   L6599D
IC102   L6599D
IC103   EL817
IC104   EL817
IC105   EL817
IC201   KIA431 43B
IC202   KIA431 43B
IC203   TLV431 RAGH
IC204   KIA431 43B
IC501   VIPER27L
IC502   EL817
IC503   EL817
IC601   FAN6961
Q101   D4N60C
Q102   D4N60C
Q103   D4N60C
Q104   D4N60C
Q201   KST2222A 1P
Q202   KST2222A 1P
Q203   KTN2222A
Q205   KST2222A 1P
Q511   KTN2222A
Q601   SD14N60
Q602   SD14N60
ZD201   MTZJ30S 30B
ZD501   MTZJ6V8S 6.8B
ZD503   UDZS15 15
ZD504   MTZJ22S 22B
D102   1N4148 T6
D103   1N4148 T6
D104   1N4148 T6
D105   1N4148 T6
D106   1N4148 T6
D107   1N4148 T6
D108   1N4148 T6
D110   1N4148 T6
D111   1N4148 T6
D112   1N4148 T6
D113   1N4148 T6
D115   1N4148 T6
D124   1N4148 T6
D201   MBRF2080CTL
D202   MBRF20100CT
D203   MBRF2080CTL
D204   D4SBL20U
D501   UF4007
D502   UF4007
D503   UF4007
D505   UF4007
D506   1N4148 T6
D507   UF4007
D508   UF4007
D509   UF4007
D510   UF4007
D511   UF4007
D601   S3V100
D602   STTH10LCD06FP
D603   1N4148 T6
D604   1N4148 T6
D605   S3V100
BD101   RS1005M
RL101   F3PA012
TH101   DSC 8D-15
TH102   DSC 8D-15
TH103   DSC 22D-9
VA101   INR 14D162
C101   3,3 nF 1000V
C102   3,3 nF 1000V
C109   47k 1kV
C113   3,3 nF 1000V
C114   3,3 nF 1000V
C125   47k 1kV
C201   1500 uF 6,3V
C202   1500 uF 6,3V
C207   330 uF 35V
C208   330 uF 35V
C209   470 uf 25V
C210   470 uf 25V
C212   33 uF 200V
C213   33 uF 200V
C501   10 uF 450V
C502   223k 630V
C503   22 uF 50V
C506   47 uF 50V
C507   22 uF 50V
C601   105J 500V
C609   68 uF 450V
C610   68 uF 450V
C611   221k 1kV
C612   221k 1kV
CX101   220 nF 275V
CX102   470 nF 275V
CX103   100 nF 275V
CY101   SD224k
CY102   SD224k
CY105   SD471k
CY106   SD101K
CY107   SD101K
CY501   SD102M
R101   1,2 Mohm
R102   10 Ohm
R103   10 kOhm
R104   10 kOhm
R106   1 Mohm
R107   820 kOhm
R108   820 kOhm
R109   820 kOhm
R110   910 kOhm
R111   100 Ohm
R112   15 kOhm
R114   5,6 kOhm
R115   13 kOhm
R116   2 Mohm
R117   150 Ohm
R118   10 Ohm
R119   47 Ohm
R120   4,7 Ohm
R121   47 Ohm
R122   4,7 Ohm
R123   2,7 Kohm
R124   100 Ohm
R125   10 kOhm
R126   10 kOhm
R128   1 Mohm
R129   820 kOhm
R130   820 kOhm
R131   820 kOhm
R132   820 kOhm
R133   100 Ohm
R134   15 kOhm
R136   7,5 kOhm
R135   1 Mohm
R137   6,8 kOhm
R138   3,3 kOhm
R139   1 Mohm
R140   120 Ohm
R141   4,1 MOhm
R143   10 Ohm
R144   47 Ohm
R145   4,7 Ohm
R146   47 Ohm
R147   4,7 Ohm
R148   100 Ohm
R149   20 kOhm
R152   10 kOhm
R157   2,2 kOhm
R158   2 Mohm
R201   100 Ohm
R202   1 kOhm
R203   2,7 Kohm
R204   150 Ohm
R205   1 kOhm
R206   1,6 kOhm
R207   270 Ohm
R208   470 Ohm
R209   10 kOhm
R210   2,2 kOhm
R211   2,2 kOhm
R214   2,4 kOhm
R215   1 kOhm
R216   1 kOhm
R217   9,1 kOhm
R218   200 Ohm
R219   2,7 Kohm
R220   200 Ohm
R221   12 kOhm
R222   12 kOhm
R223   18 kOhm
R224   10 Ohm
R225   10 kOhm
R226   10 kOhm
R227   51 kOhm
R228   51 kOhm
R229   51 kOhm
R230   3 kOhm
R231   1,8 kOhm
R232   2,7 Kohm
R233   1 kOhm
R239   18 kOhm
R240   18 kOhm
R241   470 Ohm
R243   100 Ohm
R244   30 Ohm
R245   30 Ohm
R246   2,7 Kohm
R247   5,1 Kohm
R248   1,8 kOhm
R249   36 kOhm
R250   36 kOhm
R251   36 kOhm
R252   1 kOhm
R253   100 Ohm
R255   10 Ohm
R259   1 kOhm
R260   10 kOhm
R261   1 kOhm
R262   1 kOhm
R501   100 kOhm
R505   2,2 Ohm
R504   2,2 Ohm
R506   10 kOhm
R507   1 kOhm
R508   10 MOhm
R509   100 kOhm
R510   10 Ohm
R511   10 kOhm
R513   560 Ohm
R601   68 kOhm
R602   33 kOhm
R603   47 Ohm
R604   100 Ohm
R605   47 Ohm
R606   10 Ohm
R607   10 kOhm
R608   0,18 Ohm
R609   10 Ohm
R611   0,18 Ohm
R612   750 kOhm
R613   750 kOhm
R614   750 kOhm
R615   750 kOhm
R616   18 kOhm
R617   1,3 kOhm
R626   10 kOhm
R650   10 Ohm
IC101   MEGA480P
IC102   AS3693B
Q701   SSM3K7002FU NC
Q702   CPH3431 ZG
Q703   BST120 LM
Q704   CPH3431 ZG
Q705   BST120 LM
Q706   CPH3431 ZG
Q707   BST120 LM
Q708   CPH3431 ZG
Q709   BST120 LM
Q710   CPH3431 ZG
Q711   BST120 LM
Q712   CPH3431 ZG
Q713   BST120 LM
Q714   CPH3431 ZG
Q715   BST120 LM
Q716   CPH3431 ZG
Q717   BST120 LM
Q718   CPH3431 ZG
Q719   BST120 LM
Q720   CPH3431 ZG
Q721   BST120 LM
Q722   CPH3431 ZG
Q723   BST120 LM
Q724   CPH3431 ZG
Q725   BST120 LM
R702   47 kOhm
R704   100 Ohm
R705   100 Ohm
R706   100 Ohm
R707   100 Ohm
R708   470 kOhm
R709   47 kOhm
R711   100 Ohm
R712   1,5 Mohm
R713   100 Ohm
R714   47 kOhm
R716   1 kOhm
R717   10 kOhm
R718   100 Ohm
R719   47 kOhm
R721   10 kOhm
R724   100 Ohm
R725   10 kOhm
R726   10 kOhm
R727   100 Ohm
R728   47 kOhm
R729   100 Ohm
R731   1 kOhm
R732   470 kOhm
R733   100 Ohm
R734   6,8 kOhm
R735   1 kOhm
R736   470 kOhm
R737   100 Ohm
R738   6,8 kOhm
R739   1 kOhm
R740   470 kOhm
R741   100 Ohm
R742   6,8 kOhm
R743   1 kOhm
R744   470 kOhm
R745   100 Ohm
R746   6,8 kOhm
R747   1 kOhm
R748   470 kOhm
R749   100 Ohm
R750   6,8 kOhm
R751   1 kOhm
R752   470 kOhm
R753   100 Ohm
R754   6,8 kOhm
R756   1 kOhm
R757   470 kOhm
R758   100 Ohm
R759   6,8 kOhm
R760   1 kOhm
R761   470 kOhm
R762   100 Ohm
R763   6,8 kOhm
R764   1 kOhm
R765   470 kOhm
R766   100 Ohm
R767   6,8 kOhm
R768   1 kOhm
R769   470 kOhm
R770   100 Ohm
R771   6,8 kOhm
R772   1 kOhm
R773   470 kOhm
R774   100 Ohm
R775   6,8 kOhm
R776   1 kOhm
R777   470 kOhm
R778   100 Ohm
R779   6,8 kOhm
R780   10 Ohm
R781   2,2 Ohm
R782   1 kOhm
R783   10 kOhm
R784   100 Ohm
R785   10 kOhm
R786   1 Mohm
R787   47 kOhm
R788   47 kOhm
R789   47 kOhm
R790   47 kOhm
R791   120 Ohm
R792   120 Ohm
R793   120 Ohm
R794   10 kOhm
R796   47 kOhm
R797   100 Ohm
R798   100 Ohm
R799   100 Ohm
R800   100 Ohm
R801   100 Ohm
R802   10 kOhm
R803   10 kOhm
R804   10 kOhm
R805   10 kOhm
R806   10 kOhm
R807   10 kOhm
R808   10 kOhm
R809   10 kOhm
R814   47 kOhm
R815   1,5 Mohm
R816   470 kOhm
R817   4,7 kOhm
R818   4,7 kOhm
R819   470 kOhm
R822   470 kOhm
R823   470 kOhm
R824   470 kOhm
R825   470 kOhm
R826   470 kOhm
R827   470 kOhm
R828   470 kOhm
R829   470 kOhm
R830   470 kOhm
R831   470 kOhm
R832   470 kOhm
R833   470 kOhm
R834   1 Mohm
R835   1,5 Mohm
R836   1 Mohm
R837   1 Mohm
R838   1 Mohm
R839   1 Mohm
PLDD-L906A   EAY60802902
PLDD-L902A   EAY60802901
PLDC-Z901A
PLDC-L901A   EAY60802801
PLDC-L905A   EAY60802802
« Последнее редактирование: 01 Октября 2020, 16:06:31 от aze1959 »
