Автор Тема: Comelit , IPNVR104BPOE , identificazione componente .  (Прочитано 880 раз)
amennone
« : 09 Августа 2020, 03:27:47 »
Hi, I hope to be in the exact section, I have this NVR under repair which is completely turned off.
I need to trace this component in smd, with burn marks.
On the net I tried to do some research but to no avail.
Thank you
Re: Comelit , IPNVR104BPOE , identificazione componente .
« Ответ #1 : 09 Августа 2020, 03:44:27 »
TPS54260
