Автор Тема: ASC20200316001  (Прочитано 621 раз)
ASC20200316001
« : 15 Июля 2020, 09:44:56 »
QN55Q7CAMFXZA, QN55Q7CDMFXZA, QN55Q75FMFXZA, QN55Q7FAMFXZA, QN55Q7FDMFXZA, QN55Q7FVMFXZA
NOTICE:
If you order any of the original panels listed below, and the panel is not available, you can order an alternate panel but you must also replace the Main Board, UPDATE TCON Data and change the Panel Type in Factory Menu to match the new panel. Please refer to the table below.
REPAIR IF YOU ORDERED THE ORIGINAL PANEL:
1) Install the new panel.
2) Check the test patterns in the Factory Menu.
3) Do a Picture Test to verify performance.
REPAIR IF YOU ORDERED AN ALTERNATE PANEL:
1) Install the new panel and the main board.
2) Go to the Factory Menu, and change the Panel Type to the new panel type according to the table
below.
3) Update TCON Data in Factory Menu according to instructions below.
4) Verify TCON new version.
5) Check the test patterns in the Factory Menu.
6) Do a Picture Test to verify performance.
