Автор Тема: Screen Burn In Test Pattern 06/05/2019  (Прочитано 763 раз)
« : 13 Июля 2020, 15:08:33 »
QN65Q8CAMFXZA, QN75Q8CAMFXZA, QN65Q9FAMFXZA, QN75Q9FAMFXZA, QN88Q9FAMFXZA,
QN75Q75FMFXZA, QN55Q7CDMFXZA, QN65Q7CDMFXZA, QN55Q7CAMFXZA, QN65Q7CAMFXZA,
QN55Q8CAMFXZA, QN65Q7FDMFXZA, QN75Q7FDMFXZA, QN55Q7FAMFXZA, QN65Q7FAMFXZA,
QN75Q7FAMFXZA, QN55Q75FMFXZA, QN55Q65FMFXZA, QN49Q6FAMFXZA, QN55Q6FAMFXZA,
QN55Q7FVMFXZA, QN65Q7FVMFXZA, QN55Q7FDMFXZA, QN82Q65FNFXZA, QN75Q65FNFXZA, QN65Q65FNFXZA, QN55Q65FNFXZA, QN49Q65FNFXZA,QN75Q6FNAFXZA, QN65Q6FNAFXZA, QN55Q6FNAVXZA, QN55Q6FNAFXZA, QN49Q6FNAFXZA, QN65Q75FNFXZA, QN55Q75FNFXZA, QN65Q75CNFXZA, QN55Q75CNFXZA, QN82Q6FNAFXZA, QN65Q7CNAVXZA, QN65Q7CNAFXZA, QN55Q7CNAVXZA, QN55Q7CNAFXZA, QN75Q75FNFXZA, QN55Q8FNBVXZA, QN55Q8FNBFXZA, QN75Q7FNAFXZA, QN65Q7FNAFXZA, QN55Q7FNAFXZA, QN75Q9FNAFXZA, QN65Q9FNAFXZA, QN82Q8FNBFXZA, QN75Q8FNBFXZA, QN65Q8FNBFXZA, QN49LS03RAFXZA, QN49LS03RAFXZA,
QN82Q90RAFXZA, QN65Q900RBFXZA, QN75Q900RBFXZA, QN82Q900RBFXZA, N98Q900RBFXZA, QN75Q80RAFXZA, QN82Q80RAFXZA, QN65Q90RAFXZA, QN75Q90RAFXZA, QN75Q90RAFXZA,
QN75Q70RAFXZA, QN82Q70RAFXZA, QN85Q70RAFXZA, QN55Q80RAFXZA, QN55Q80RAFXZA,
QN75Q60RAFXZA, QN82Q60RAFXZA, QN49Q70RAFXZA, QN55Q70RAFXZA, QN55Q70RAFXZA,
QN43Q60RAFXZA, QN49Q60RAFXZA, QN55Q60RAFXZA, QN55Q60RAFXZA, QN65LS03RAFXZA, QN55LS03RBFXZA, QN55LS03RAFXZA, QN43LS03RAFXZA, QN49LS03RAFXZA
Subject: How to idenftify Screen Burn-In on an LED TV
Instructions: Use the .jpg test pattern attached to the GSPN Service Tip page to identify burn-in on TVs. Follow the steps below to do the test.
1. Download the test pattern file “TV Burn In Test Pattern.jpg” from the GSPN Service Tip page, and then save the file to a USB drive.
2. Insert the USB drive into a USB port on the TV or the One Connect Box.
3. The TV will prompt you to play the contents in the USB. Select Play, and then select the file “TV Burn In Test Pattern.jpg” to display the test pattern.
4. If the TV does not display the TV prompt, press the Home button on the remote, and then navigate to
