Автор Тема: kss213c no disc  (Прочитано 1035 раз)
papele
kss213c no disc
« : 11 Июля 2020, 03:40:51 »
good evening i have a cd player with sony mechanics kss213c. i cleaned the lens but the cd turns and then it stops with "no disc" error you tell me if i can clean the lens inside. the laser is good because the disk spins. but it doesn't find the trace 0. :ar:
Aristak
Re: kss213c no disc
« Ответ #1 : 12 Июля 2020, 16:30:28 »
Did you check the loop? laser is better to change
papele
Re: kss213c no disc
« Ответ #2 : 13 Июля 2020, 16:07:07 »
hi.
coil focusing? :br:
Aristak
Re: kss213c no disc
« Ответ #3 : 13 Июля 2020, 22:32:38 »
Yes, the laser head.
Василииий
Re: kss213c no disc
« Ответ #4 : 21 Июля 2020, 15:31:53 »
The lens will SAG over time . You can try to lift it . Perhaps the disk will read it . If it doesn't help, then just replace the laser .
