Автор Тема: LV-280  (Прочитано 513 раз)
LV-280
« : 08 Июня 2020, 22:13:05 »
MAIN SOFTWARE UPDATE – VERSION 1.230
Model LC-37D44E/S/RU-BK/GY
LC-32D44E/S/RU-BK/GY
LC-26D44E/S/RU-BK/GY
General
We inform you of the main software update to version 1.230. The following is solved in this release.
• Picture flickering by component input from a STB (Set Top Box)
Corrected software so that the film mode detection is prohibited at the time of the progressive mode input.
Servicing
Check the current software version in the unit.
If the software version is less than 1.230, update the software to version 1.230.
After update, make sure the software version is 1.230 in the unit.
For the details on how to upgrade, please refer to the Service Manual.
Model Main software file name (Version 1.230)
LC-37D44E/S/RU-BK/GY 37D44E_V1230K.bin
LC-32D44E/S/RU-BK/GY 32D44E_V1230S.bin
LC-26D44E/S/RU-BK/GY 26D44E_V1230C.bin
Note:
With this software update, the user settings will be kept in the unit.
If you perform the delivery setting (Factory-Init), the user settings will be initialized.
Production
change
From August
