Автор Тема: LV-276  (Прочитано 461 раз)
LV-276
« : 08 Июня 2020, 22:11:07 »
LC-32D44E/S/RU-BK
LC-32D44E/S/RU-GY
General The Power/Inverter unit has been fixed on the backlight chassis with both the Power/Inverter PWB
holder and the screws. However, if the Power/Inverter PWB holder is not installed and clipped properly,
the Power/Inverter PWB is raised away from the lamp connector. In that case, there is a possibility that
an arc discharge generates between the lamp connector and it causes the contacts to damage.
(Ref# 17 - Power/Inverter PWB holder: LHLDZA934WJKZ)
Servicing To avoid the occurrence of this problem, perform the confirmation of the Power/Inverter PWB holder
installation condition whenever the above mentioned models require service.
With the confirmation, if the Power/Inverter PWB holder installation is incomplete, install and clip the
holder properly and fix the Power/Inverter unit with the holder and the screws.
Follow the installation procedure in the next page of this technical report.
