Автор Тема: LV-314  (Прочитано 533 раз)
LV-314
« : 08 Июня 2020, 22:03:11 »
Subject SCREEN BECOMES BLACK/WHITE
Model Models
Inches Model name Serial number range
LCD panel module ITEM
LC-37D44E ∗∗∗∗11112 ~ 903∗∗∗∗∗∗ R1LK370T3GW2AY I
37”
LC-37RD2E ∗∗∗∗11112 ~ 903∗∗∗∗∗∗ R1LK370T3LZ70Z II
LC-32RD8E ∗∗∗∗11112 ~ 903∗∗∗∗∗∗ R1LK315T3GW2BY/U/L/Q V
32”
LC-32RD2E ∗∗∗∗11112 ~ 903∗∗∗∗∗∗ R1LK315T3LZ60Z VI
26” LC-26D44E ∗∗∗∗11112 ~ 903∗∗∗∗∗∗ R1LK255T3GW2AY/GW20Y V
Symptom
Cause
Screen becomes black (white) and no picture appears. Or screen becomes white with colored lines.
Gate driver IC of the LCD panel is defective.
(Shorted-circuit between VGH and GND line in the Gate driver IC circuits)
Servicing
When the unit requires service due to the above mentioned symptom, take the below steps.
1. Remove the defect LCD panel module.
2. Measure the resistance value between VGH and GND at the FPCs of the removed LCD panel module.
For how to measure resistance value, see the next pages of this technical report.
If the resistance value is 1k ohms or less, the Gate driver IC is defective(short-circuit).
Replace the defective LCD panel module with a new one which has the new Gate driver IC(VHIT6LE7+++-1L).
3. To repair the defective LCD panel module, it is necessary to change all the Gate driver IC to the new Gate driver
IC (VHIT6LE7+++-1L). After changing to the new Gate driver IC, one black dot is added to the barcode of the
LCD panel module. See the next page of this technical report.
Parts
Parts code
ITEM Description
OLD Q’ty NEW Q’ty
Interchangeability
I 37” LCD panel module R1LK370T3GW2AY 1 R1LK370T3GW2AU 1 C
II 37” LCD panel module R1LK370T3LZ70Z 1 R1LK370T3LZ70U 1 C
III 32” LCD panel module R1LK315T3GW2BY/U/L/Q 1 R1LK315T3GW2BH 1 C
IV 32” LCD panel module R1LK315T3LZ60Z 1 R1LK315T3LZ60U 1 C
V 26” LCD panel module R1LK255T3GW2AY/GW20Y 1 R1LK255T3GW20U 1 C
Note: The NEW LCD panel module has the new Gate driver IC (VHIT6LE7+++-1L). For the details, see the next page.
