Автор Тема: Samsung UE28F4000AW  (Прочитано 1494 раз)
papele
Samsung UE28F4000AW
« : 03 Апреля 2020, 17:34:01 »
Good morning everyone. I have a samsung  mod  UE28F4000AW led tv that can be seen with a darker image. Some led parties. I am looking for the service manual. You can help me.thank you. :br:
Re: Samsung UE28F4000AW
« Ответ #1 : 03 Апреля 2020, 18:55:22 »
MainBoard BN41-01987A BN94-06755T
http://televid-sib.org/index.php?topic=23763.0
papele
« Ответ #2 : 03 Апреля 2020, 21:58:08 »
Psu?I have dark image. Suspected led voltage. Thank you.  :good:
« Ответ #3 : 03 Апреля 2020, 22:14:40 »
Check the LED backlight with the device. If there is no device, then disassemble the matrix.
dima2007
« Ответ #4 : 03 Апреля 2020, 23:50:29 »
Most likely, the problem is in the LEDs. Clearly you need to disassemble the matrix and check all the LEDs
papele
« Ответ #5 : 04 Апреля 2020, 04:48:16 »
Maybe some led in short otherwise it would be dark? Also you hear hissing from psu. :good:
