Автор Тема: 595198389759977BR  (Прочитано 562 раз)
595198389759977BR
« : 16 Августа 2019, 13:37:45 »
Document Category: Knowledge Base
Subject: After replacing the DG pcb, the screen is just white with a blue dot in middle of screen.
Model(s) Affected: TX-26LXD50 TX-26LXD500 TX-32LXD500 TX-32LXD52
Problem / Issue After replacing the DG pcb, the screen is just white with a blue dot in middle of screen
and no remote functions.
Is this normal and how can it be resolved?
Carry out a self check on this unit and then switch off via the on/off switch and back on
again to cure this effect
