Автор Тема: ASC20161116001  (Прочитано 714 раз)
ASC20161116001
« : 23 Июля 2019, 13:47:37 »
UN40K5100AFXZA, UN40KU7000FXZA, UN43KU7000FXZA, UN43KU7500FXZA, UN49KU7500FXZA, UN55KS8000FXZA,
UN55KS800DFXZA, UN55KS8500FXZA, UN55KS850DFXZA, UN55KU7500FXZA, UN55KU750DFXZA, UN60KS8000FXZA,
UN60KS800DFXZA, UN65KS9800FXZA, UN65KU649DFXZA, UN65KU6500FXZA, UN65KU650DFXZA, UN65KU7000FXZA,
UN65KU700DFXZA, UN65KU7500FXZA, UN65KU750DFXZA, UN70KU6300FXZA, UN70KU630DFXZA, UN78KU7500FXZA,
UN78KU750DFXZA
SUBJECT: Power Supply is dislodged
POSSIBLE SYMPTOMS: Unable to plug the power cord into the back of the TV.
REPAIR GUIDE:
Required Parts (See Appendix 1)
- SMPS (Power Supply)
- Lead Connector(s):
o Lead Connector between Main and SMPS
o Lead Connector between SMPS and Panel if applicable
Repair Steps
1) Remove the back cover. (For instructions, please refer to the 2016 Repair Guide in GPSN > Tech Tips.)
2) Replace the SMPS and any damaged cables
※ CAUTION: When installing the Screwless SMPS board, verify the board is properly positioned in all mounting slots. The number and the location of mounting slots vary by model and size.
« Последнее редактирование: 23 Июля 2019, 15:26:37 от aze1959 »
