Автор Тема: 09TV122R1  (Прочитано 550 раз)
09TV122R1
« : 26 Июня 2019, 13:41:53 »
EX-2L_Basil, EX-2L_Basil_Sat, EX-2L_Coriander,
EX-2L_Coriander_Sat, EX-2L_Eco_Basil, EX-2L_Ginger Chassis
The LED may flash 14 times.
CAUSE
Open fuse F1300 on the BA board.
1. If fuse F1300 is open, replace it.
Description Part number
Fuse, Micro (1608) / 3.15A 24V 1-576-850-21
2. After exchanging F1300, check the following.
• Panel LVDS connector or T-con board defective? / Short-circuit in the power lines?
• LVDS cables damaged or having short-circuit?
• Connector CN4501 in BA board defective?
• Short-circuit in F1300 power supply line? Check by pin 13 (Panel_VCC) in the CN1300 connect
