Автор Тема: PCZ1707143BE  (Прочитано 689 раз)
PCZ1707143BE
« : 23 Июня 2019, 10:06:03 »
Models: 1) TX-55DX600B TX-55DX600E TX-55DX603E TX-55DXF687 TX-55DXN688
TX-55DXR600 TX-55DXT686 TX-55DXU601 TX-55DXW604 TX-55DXX689
2) TX-55DX650B TX-55DX650E TX-55DX653E TX-55DXW654
Chassis: LA64
Subject: Replacement of Circuit Board A – EEPROM data update (depends on the LCD Panel).
Method: After replacement of Circuit Board A check the part number of LCD panel at Customer No.
on Panel Label.
Procedure of rewrite of EEPROM data:
1. Download the EEPROM data file embedded in this PDF file. (SDDL.SEC)
2. Copy an following file to root folder of the USB flash memory.
File name: SDDL.SEC
3. Turn on the main power of the TV set.
4. Insert the USB flash memory with data into the USB terminal of TV set.
The following message is displayed (example (TX-55DX600B)).
Not Required to
rewrite data
Required to rewrite
data
Model: Current Customer No.
on Panel Label
New Customer No.
on Panel Label Description
Models above 1) L5EDDYY00849 L5EDDYY00966 LCD PANEL
Models above 2) L5EDDYY00872 L5EDDYY00967 LCD PANEL
