Автор Тема: hyper terminal on TV without serial port.  (Прочитано 743 раз)
papele
« : 13 Мая 2019, 16:33:53 »
Hello I would like to upgrade a lcd tv with hyper terminal. the tv does not have rs 232 only usb.i can use a serial usb 232 converter? how to use hyper terminal even when the tv does not start?thank you.
papele
Re: hyper terminal on TV without serial port.
« Ответ #2 : 13 Мая 2019, 17:36:37 »
thank you CAIIIA.can I use the serial usb converter/rs232?
« Ответ #3 : 13 Мая 2019, 20:21:51 »
Probably yes
