Автор Тема: tv plasma philips 40PFL3606D/78 no video  (Прочитано 731 раз)
eletmoraes
initially was not even calling. I went to check the source by finding the MQPF6N80 mosfet totally short and the smd 10R resistor (R514) open beyond the fuse of the input and also the U501 (NCP1207A) burnt. After replacing these components the TV turned on again only putting an antenna and tuning the channels detects, type, 7 channels but the picture does not appear the same thing when I put the PC option, it is without image. only have no video signal. This TV has already come from another workshop.
CODE OF THE TV BOARDS OF THE MAIN AND THE T-CON . Photo attached
after completing the tuning of the channels by the ANT (AR) option, the image appeared all dotted and multi-colored. I suspect the defect is on the t-con plate
digital channels found -> 15
analog channels found -> 0
I exit the menu and when I select a broadcast channel, for example, the tuned channel nothing of the broadcast picture appears
« Последнее редактирование: 18 Мая 2019, 09:23:13 от EWB2009 »
Re: tv plasma philips 40PFL3606D/78 no video
« Ответ #1 : 13 Мая 2019, 13:02:50 »
elemorales. its LCD TV
« Ответ #2 : 13 Мая 2019, 16:45:43 »
What is the voltage on the electrolytic capacitor 100uF 450V when the TV is on?
eletmoraes
« Ответ #3 : 16 Мая 2019, 07:47:55 »
необходимо, чтобы телевизор снова работал нормально:
-> изменение указанных компонентов и обновление программного обеспечения (прошивки)
тема завершена
