Автор Тема: Samsung UE50H6200AYXZT spento  (Прочитано 3135 раз)
amennone
Samsung UE50H6200AYXZT spento [Решено]
« : 29 Апреля 2019, 05:30:32 »
UE50H6200AYXZT
U8DC
BN41-02156A
BN41-02156A
BN41-02156A
INNOLUX V650HP1-CPS1
BN44-00711A
BN44-00711A
BN44-00711A
BN44-00711A
A warm greeting to all. On this tvc samsung UE50H6200AYXZT (Chassis: U8DC) I found exploded IC206 = Z3015PI. The TVC was completely turned off. With the replacement of this component the situation remained unchanged. On pin 2 (VIN) of IC 206 the standby voltage is present about 9 volts, while in output pin 8 (VOUT) no voltage, there should be 5 volts.
I injected a voltage of 5 volts on pin 8, but the TV still shows no signs of life. All the power supplies are missing.
The main board is signed BN41-02156A, in vain the searches on the web of the same scheme.
Apart from the main layout, I need some input to continue with the repair, thanks for the safe and valuable advice.
« Последнее редактирование: 29 Апреля 2020, 08:47:31 от vornst »
Re: Samsung UE50H6200AYXZT spento
« Ответ #1 : 29 Апреля 2019, 05:37:40 »
amennone
« Ответ #2 : 29 Апреля 2019, 05:47:04 »
Hello artur008,  and thanks for the reply .
Do you have the complete main board layout?
amennone
« Ответ #3 : 29 Апреля 2019, 05:59:24 »
I have no doubt that LX has not been paid.
So the voltage from LX?
« Ответ #4 : 29 Апреля 2019, 06:02:21 »
What is your native language?
amennone
« Ответ #5 : 30 Апреля 2019, 04:56:39 »
Thanks to the indications of artur008 I identified the faulty component
D204, replaced with zener 4v7.
The TV works, the tensions are right.
The problem is the image, the screen is dark, audio ok.
From the scart output the image is ok.
The panel looks unlit.
If I disconnect the cable from the T-CON (INNOLUX V650HP1-CPS1) to the main-board the panel is bright.
On the T-CON board, the diode D407 is off, D405 and D406 are on.
What could be the problem ?
D407 must be on?
What can I check?
Thank you and good job to everybody .
« Ответ #6 : 30 Апреля 2019, 05:17:29 »
"Matrix: BN41-02156A"  >:(
amennone
« Ответ #7 : 30 Апреля 2019, 06:00:30 »
What do you mean ?
I tried disconnecting the cables where you put the "X", but the panel remains off
« Ответ #8 : 30 Апреля 2019, 06:27:12 »
Does the screen light up?
amennone
« Ответ #9 : 30 Апреля 2019, 18:49:26 »
Yes, the screen turns on, if the cable from the T-con to the main board is disconnected.
« Ответ #10 : 30 Апреля 2019, 19:08:18 »
If you disconnect the connectors that I indicated in the figure, the screen backlight lights up?
amennone
« Ответ #11 : 01 Мая 2019, 05:05:01 »
No
« Ответ #12 : 01 Мая 2019, 05:20:58 »
VGL, VGH, VAA, VDD, V12V, VD33V, B1_5V_PW, B12V_PW, B3_3V_PW, B2_5V_PW?
amennone
« Ответ #13 : 01 Мая 2019, 23:55:50 »
Where should I check these tensions?
serg-161
« Ответ #14 : 02 Мая 2019, 00:17:19 »
T-con
/Кин-дза-дза!/
amennone
« Ответ #15 : 02 Мая 2019, 02:34:30 »
VGL       =  -7v8
VGH       =   0v
VAA       =   0v
VDD       =   Not identified on the T-CON circuit
V12V       =   12v
VD33V       =   3v2
B1_5V_PW  =   1v5
B12V_PW   =   12v
B3_3V_PW  =   3v3
B2_5V_PW  =   2v5
others on T-CON
B1_1V_pw  =   1v1
PWRON     =    0v
VDDAM_L   =   0v
VREF1     =      0V
VGHP      =      0V
VGOFF     =     0v
XAO       =      3v2
thank you for your attention and best regards
amennone
« Ответ #16 : 14 Мая 2019, 05:43:30 »
Привет, я сделал, как вы сказали, несколько раз прогрел процессор, ситуация осталась прежней.
Я подал напряжение 3 на 3 на PWRON, светодиод D407 загорелся, но дисплей не дает изображения, и панель продолжает оставаться темной.
Вот ситуация:
PWRON с внешним напряжением 3v3
VGL = -7v8 -7v8
VGH = 0v 0v
VAA = 0 В 17 В
V12V = 12v 12v
VD33V = 3х2 3х2
B1_5V_PW = 1 на 5 1 на 5
B12V_PW = 12 В 12 В
B3_3V_PW = 3v3 3v3
B2_5V_PW = 2 на 5 2 на 5
B1_1V_pw = 1v1 1v1
PWRON = 0 В с внешним напряжением 3 В 3
VDDAM_L = 0 В 8 В
VREF1 = 0V 1v3
VGHP = 0 В 29 В
VGOFF = 0v 0v
XAO = 3х2 3х2
VCM_CF = 0 7v2
VDD = 3х2 3х2
На данный момент все, что остается, это заказать новый T-CON, надеясь, что дисплей в порядке.
Любые другие предложения?
