Автор Тема: PCZ1011169TE  (Прочитано 600 раз)
PCZ1011169TE
« : 07 Апреля 2019, 09:14:44 »
TX-L32GF22, TX-L32GN23, TX-L32GS21, TX-L32GT24, TX-L32GW20
TX-L37GF22, TX-L37GN23, TX-L37GS21, TX-L37GT24, TX-L37GW20
Chassis: GLP25
Date: 6th December 2010
Symptom: DVB-S block noise on start up (from cold condition)
Remedy: Add two capacitors to new location on the XS PCB to stabilize power supply voltage.
Method: Please choose one of the following methods - Option A or Option B - to modify the XS PCB.
Both methods are equivalent, choose one based on your skills and equipment available.
Option A: Add two parallel capacitors P/N: F1K0J226A008 (on the top of each other) on the XS PCB.
Solder these parallel capacitors between GND of C6700 and the point TP6700.
