Автор Тема: PCZ1006116TE  (Прочитано 558 раз)
PCZ1006116TE
« : 07 Апреля 2019, 02:47:58 »
TX-P42GW20, TX-P46GW20, TX-P50GW20
TX-P42GF22, TX-P42GN23, TX-P42GS21, TX-P42GT24, TX-P46GQ21
TX-P42V20E, TX-P50V20E, TX-P50V20L
TX-P42GT20E, TX-P42VT20E, TX-P46VT20E
Chassis: GPF13DE
Date: 12th April 2011
Subject: Picture block noise and audio dropouts on DVB-S signal
Symptom When watching some satellite HD channels, there is a possibility of picture block noise and
audio dropouts occuring during the first 15 minutes after switching on the TV set.
Remedy: Change XS PCB assembly. There are two different methods how to do it:
Method 1: Exchange XS PCB assembly by new part
Method 2: Modify the existing XS PCB assembly
And change internal wire dressing, see last page.
Order a replacement XS PCB (part: TXFUX01LQUEG)
And change internal wire dressing, see last page (Fig. 4).
Or
Method 2: XS PCB assembly modification
Step 1
Check PCB label suffix (Fig.1). If there is "AB" replace the capacitors
on the original XS PCB with new parts as indicated below (Fig.2):
If the suffix is "AC" then there is no need to modify the capacitors.
Ref. No. Part Number Description
C6700 F1H1A225A051 2.2uF, 10V, 10%
C6708 F1H0J475A041 4.7uF, 6.3V, 10%
C6711 F1H0J475A041 4.7uF, 6.3V, 10%
C6714 F1H0J475A041 4.7uF, 6.3V, 10%
C6732 F1H0J475A041 4.7uF, 6.3V, 10%
