Автор Тема: PCZ1205105TEc  (Прочитано 553 раз)
PCZ1205105TEc
« : 07 Апреля 2019, 02:46:35 »
Subject : Colour noise in the dark scenes
Model : Please see list on page 2 for PEAKS and PPDP DCC software version / Please see list on page 2 for Panel software version
Symptom / Intermittently a colour noise appears on dark areas of the screen.
Cause : Please see the pictures below for an example.
Remedy / Step 1: Upgrade the PEAKS software
Method : Step 2: Upgrade the Panel PDP DCC software
Preparation:
1. Obtain 2 SD Cards, one for use in step 1, one for use in step 2.
The card capacity must be between 128MB and 2GB and they should be standard speed.
2. Obtain a copy of the two different firmware versions - the PEAKS software (for Step 1),
and the Panel software (for Step 2) - from your usual service source.
3. Copy the compressed PEAKS software file to a computer and unzip the file.
4. Copy the SDDL file onto the root directory of SD Card 1 (for Step 1).
5. Copy the compressed Panel software file to a computer and unzip the file.
6. Copy the SDDL file onto the root directory of SD Card 2 (for Step 2).
Eu & UK
PDP
Frequency level
Model :
High Low A few One
Technical Information
Cases reported (country)
2011 Models
- The progress bar will appear.
- The message "System initializing" will be displayed on the screen
- Wait whilst the TV set reboots (about 3 minutes) and the "default screen" is displayed.
1. Turn on the TV set.
on the screen (about 5 minutes)
4. When the message appears, remove SD Card 1 from the SD Card slot.
2. Insert the SD card 2, with the file prepared in step 6 above, into the SD Card slot.
- Do NOT remove SD Card 2 while the LED is flashing
- The panel will power down, and the red LED will start to flash.
5. Turn off the TV set.
3. Using the Cursor buttons on the remote control, select YES, then press the OK button to start the software upgrade
- Wait until the progress bar has reached 100%, and the message "Please turn off
