Автор Тема: PCZ1205105TEb  (Прочитано 584 раз)
PCZ1205105TEb
« : 07 Апреля 2019, 02:45:06 »
Subject : Colour noise in the dark scenes
Model : Please see list on page 2 for PEAKS and PPDP DCC software version / Please see list on page 2 for Panel software version
Symptom / Intermittently a colour noise appears on dark areas of the screen.
Cause : Please see the pictures below for an example.
Remedy / Step 1: Upgrade the PEAKS software
Method : Step 2: Upgrade the Panel PDP DCC software
Preparation:
1. Obtain 2 SD Cards, one for use in step 1, one for use in step 2.
The card capacity must be between 128MB and 2GB and they should be standard speed.
2. Obtain a copy of the two different firmware versions - the PEAKS software (for Step 1),
and the Panel software (for Step 2) - from your usual service source.
3. Copy the compressed PEAKS software file to a computer and unzip the file.
4. Copy the SDDL file onto the root directory of SD Card 1 (for Step 1).
5. Copy the compressed Panel software file to a computer and unzip the file.
6. Copy the SDDL file onto the root directory of SD Card 2 (for Step 2).
