Автор Тема: firmware toshiba  (Прочитано 1464 раз)
saveriuccio
firmware toshiba
« : 23 Июля 2018, 19:39:27 »
Hello everyone
someone knows where to find the firmware for this tv toshiba 32av615dg
on the toshiba website does not exist
thank you
bibicoco
Re: firmware toshiba
« Ответ #1 : 29 Июля 2018, 18:20:30 »
Attached is a .rar file where you find 2 identical firmware and the difference in the panel, then see which mounts and install the one with the right panel.
http://televid-sib.org/index.php?topic=53996.0
« Последнее редактирование: 29 Июля 2018, 21:07:30 от aze1959 »
saveriuccio
« Ответ #2 : 03 Августа 2018, 21:37:44 »
Hello.
I thank you for the firmware. Only I forgot to say that the TV is off and only has the green LED on. There's a way to load it. Thanks
saveriuccio
« Ответ #3 : 03 Августа 2018, 22:42:34 »
greetings to all. I found the firmware but it does not work. since the tv has the green LED on steady and 'not part I would need the firmware INIT_CLEAR.bin. and the other two associated files. can someone help me. thank you
saveriuccio
« Ответ #4 : 04 Августа 2018, 16:01:25 »
Resolved
tv toshiba 32av615dg green led fixed black screen audio absent
all regular tension.
corrupt firmware problem.
upload files to the rar folder on usb pen 32
« Последнее редактирование: 29 Июля 2021, 22:19:39 от aze1959 »
bibicoco
« Ответ #5 : 04 Августа 2018, 16:44:04 »
The 2 files that I sent you, depending on the type of panel, these are programmed on the spyflash by programmer, in the case that with the firmware via USB is not accepted.
