Автор Тема: 506  (Прочитано 1081 раз)
« : 06 Июля 2013, 21:44:21 »
Model: SU-27FD3, SU-32FD3, SU-36FD3 No. 506
Subject: Repair of TV Stand Date: October 16, 2000
Symptom:
(116X) Gray plastic decorative part (ornamental cover) falls off during TV Stand assembly or
when placing/removing TV set from stand.
The ornamental front cover should not be installed, until the set is placed properly on top of
the stand. If the cover is installed before installing the TV, the cover can be pushed forward
causing the staple, which attaches the rail that the cover slides onto, to become loose.
Note: The Assembly Instruction Manual explicitly states that the TV positioned on the stand before placement of ornamental covers. Affixing the o srnhaomuledn btael pcroovpeerr plyrior troe minosvtaall loaft itohne odfe TcoVr aptriovvei dpeasr tp.otential for high impact to part attached by staple resulting in the
SOLUTION: Reattach existing plastic parts with 1" Panel Board Nails provided by manufacturer's
Service Center. Manufacturer: Tocabi America Corporation. Swoitnhy sOhpoertr adteosrc srhipotuiolnd roef cpormobmleemnd ( etxh:a st tcaupsletos mreemr ocovemdp, leettce. )T. VF aSxt acnadrd W, aalrornagn twy iCthard tcoo p(6y1 o9f) s6a5le6s- 8r1ec8e1i.p At,fter this operation, customer will receive "FD3 fix-it kit" within 5
« Последнее редактирование: 21 Января 2015, 10:44:36 от aze1959 »
