Автор Тема: TB-08-09  (Прочитано 630 раз)
TB-08-09
« : 05 Мая 2018, 02:38:01 »
TC-26LX85
TC-32LX85
Code:
B61
Model Year: 2008
Date:
Sept 15, 2008
Symptom: Audio distortions, mostly noticeable during commercial programming.
Cause: Some stations send out of the specs signal causing audio distortion in higher frequencies.
Remedy: Software upgrade is needed if unit has serial number before specified below:
**82330746 for TH26LX85
**82340342 for TH32LX85
Procedure: Software Hudson2 version 1.1 is available from our extranet and has to be loaded to SD card.
It contains 3 files as on the picture below.
Perform the upgrade following below steps:
1. Turn on TV and insert SD card into SD card slot. TV will show the screen as in Fig.1
