Автор Тема: I need diagram schematic msi-7309 ver: 2.1 ( K9N6PGM2-V2 )  (Прочитано 1574 раз)
eletmoraes
« : 02 Октября 2017, 00:39:28 »
The processor cooler ended up locked which caused the processor to heat up and also burned the mosfet Q17 transistor. I replaced the transistor but the board does not raise video even though the processor exhibits apparently normal heating after transistor switching. If I got the schematic diagram of the board it would help a lot to find the defect.
OlegLeon
Re: I need diagram schematic msi-7309 ver: 2.1 ( K9N6PGM2-V2 )
« Ответ #1 : 23 Января 2018, 02:33:21 »
If you need - see database on the motherboard MSI here
http://televid-sib.org/index.php?board=1294.0
