Автор Тема: 05-C/M-E002  (Прочитано 804 раз)
05-C/M-E002
« : 20 Сентября 2017, 08:09:38 »
Product : CDT Monitor Bulletin No. : 05-C/M-E002
Model : LIBRA Project(LB15VS, LB17LS/T, LB17KS/T)Bulletin Date : Feb. 04, 2005
Buyer : Samsung
Subject : Plus One SVC for LIBRA CDT Monitor Raster Distortion Issues.
Background :Some of units are appear Raster Distortion at 53KHz under H-position change time
during first initial mass Production.
Root Cause Horizontal out put noise (JP35) impact to High Voltage process
Solution : - JP35 Delete and GND 40mm Wire connect between D405 and D406 location.
. Raster Distortion Countermeasure : delete the JP35
. Vertical Bounding Countermeasure : Jumper wire connector between D405 to D406
