Автор Тема: I accept tips or suggestions to repair scratches on Acer's upper casing  (Прочитано 1061 раз)
eletmoraes
I have an Acer that on the top front of the notebook has scratches near the pads as attached picture
What can I do to recover
Re: I accept tips or suggestions to repair scratches on Acer's upper casing
« Ответ #1 : 10 Сентября 2017, 10:36:09 »
you can dye
« Ответ #2 : 10 Сентября 2017, 15:38:38 »
想想。 之前提出这样的问题
Dompti
    • EDV-Dompteur.de
« Ответ #3 : 19 Сентября 2017, 16:40:18 »
If the color is not important, then you could remove it completely and smooth the surface with fine sanding paper.
If you absolutely want the silver color back, then you could use a spray bottle after sanding.
