Автор Тема: Toshiba 40L2456D логотип в течение нескольких секунд после 20 секунд. ожидание  (Прочитано 2862 раз)
divubi2004
The logo appears on the TV for a few seconds then after about 20 seconds it returns to stand-by
I checked the power and it's okay. I'have forced the power on and the BL ON and all the voltage are ok and the backlight it's ON.
I have reprogrammed the spi with the file read from another tv but the problem it's the same.
I think it may be a nand data problem or a failure on the main.
you have the dump of nand or the schematics for this tv ?
I tried with the usb update taken from the toshiba site but it does not work
divubi2004
Thank you for the service manual.
I checked the tensions and they are all ok
at this point the last thing to try it's reprogramming the nand but I can not find the file
Telefuntik
divubi2004
I tried to upload the update from usb but it wasn't possible. I tried it both in the standard and forced way and also renaming the file ( the instruction are in service manual ) but there was no result. The file loaded on the spi is tested and working
LGбахт-тел
  • Желаю всем добро.
Ты сам не работаешь, официальная прошивка всегда будет работать.
Ты что-то не правильно делаешь.
После скачивание надо извлечь файл в корень юсб накопителя.
Лучше верить, чем не верить, потому что с верой все становится возможным.
Может флешка не подходит. Попробуй другую.
aniello68
