Автор Тема: 11TV033R0  (Прочитано 675 раз)
11TV033R0
« : 02 Сентября 2017, 09:13:55 »
11TV033R0
8/4/2011
Ref nr.
11TV033
Model
AZ1L_2B-1.5, AZ1N_3A-2, AZ2F_3A-2,
KDL-37EX720
Subject
Cracking Sound
Symptom:
A cracking sound may be heard from certain mechanical parts.
Cause:
Shrinkage / expansion of plastic parts, mainly at the joint area between the rear cover and bezel.
Remedy:
1. Explain to the customer that the problem is due to the cause mentioned above. Keep on persuading if necessary.
(<= RECOMMENDED)
2. Only if the customer is not satisfied with this explanation and urges a repair, apply the countermeasure indicated
below.
Adding unwoven cloth tape
2-1. Remove the rear cover from the TV.
2-2. Adhere pieces of unwoven cloth tape, as indicated below (Example for KDL-40HX800).
Description Part number
Cushion A 4-096-343-51
2-3. Make sure the joint rib between rear cover and bezel is not covered.
NOTE: Use line 1 in case problem is solved by simply explaining to customer. Use line 2 in case of actual repair.
« Последнее редактирование: 03 Декабря 2023, 03:22:25 от aze1959 »
