Автор Тема: 11TV025R0  (Прочитано 684 раз)
11TV025R0
« : 02 Сентября 2017, 09:12:17 »
11TV025R0
KDL-32EX720, 721, 723, 724, 725, 726, 727, 728, 729
KDL-46EX720, 721, 723, 724, 725, 726, 727, 728, 729
Subject:SLCD, AUO & FOXCONN Panel Compatibility
When replacing the power supply (Static Converter) board, make sure only to use compatible parts.
CAUSE
SLCD, AUO and FOXCONN panel each use different voltage ranges.
Refer to the info below to identify the Static Converter board to be used.
IMPORTANT: For 32 inch models, when changing from a normal SC Board (G10A or G10B) to an improved one
(G10AV or G10BV), please refer to TB 11TV024 for further instructions.
Panel Static Converter Board
Size Label info P/N Label info P/N
32“
SLCD 32EDL (LTY[Z]320HJ01-XXX) 1-811-339-11 G10A 1-474-294-1x
G10AV 1-474-358-1x 1-474-358-11
AUO (T315HW07 V7) / G10B 1-474-295-1x
G10BV 1-474-359-1x 1-474-359-11
FOXCONN (FDMF315NN01) / G10A 1-474-294-1x
46”
SLCD 46EDL (LTY[Z]460HJ05-XXX) 1-811-341-11 G5D 1-474-309-1x FX0009411
AUO (T460HW08 V2) / G5E 1-474-318-1x FX0040612
11TV025R1
Subject: Panel / PSU Compatibility [REVISION 1]
When replacing the panel or power supply (Static Converter) board, make sure only to use compatible parts.
CAUSE
IMPORTANT: For 32 inch models, when changing from a normal PSU (G10A or G10B) to an improved one
32“
G10AV 1-474-358-1x
AUO (T315HW07 V7) 1-811-353-11 G10B 1-474-295-1x
G10BV 1-474-359-1x
FOXCONN (FDMF315NN01) 1-811-424-11 G10A 1-474-294-1x
G10AV 1-474-358-1x
46” SLCD 46EDL (LTY[Z]460HJ05-XXX) 1-811-341-11 G5D 1-474-309-1x
AUO (T460HW08 V2) 1-811-355-11 G5E 1-474-318-1x
« Последнее редактирование: 03 Декабря 2023, 03:15:43 от aze1959 »
