Автор Тема: ASC20130429001  (Прочитано 762 раз)
ASC20130429001
« : 30 Июля 2017, 06:44:20 »
UN46ES7500, UN55ES7500,
UN60ES7500, UN46ES7550,
UN55ES7550, UN60ES7550,
UN46ES8000, UN55ES8000,
UN60ES8000
SUBJECT: Power Cycling / Reset
SYMPTOMS:
- The TV may display vertical lines
- The WD Count in Service Menu>Control>Sub Option is higher than 0
REPAIR:
This issue can be resolved by either Step 1 or
1) Check the power cable between
a. If the cable or connector on the
b. If the cable and the connectors
2) Check the Lot number of the LVDS connector on
than 120531, replace both the
Note: Consult the Samsung Service Website at
on this product.
Discoloration on pins 17 and 19
contain warnings to advise non
serious injury or death. Information provided in this
or a frozen image on the screen and then power OFF and ON by itself
0.
2 below:
the Main board and the SMPS (Power Supply).
SMPS is discolored, replace the cable and SMPS board.
onnectors are both OK, do not replace the cable or SMPS board
the T-Con board. If the first 6 digits of the Lot number is lower
LVDS cable and T-Con board.
service.samsungportal.com for the Service Manual and oth
