Автор Тема: 65EF9500 WebOS 2.0 OLED TV COLOR TEMPERATURE SETTINGS  (Прочитано 1086 раз)
« : 26 Февраля 2017, 07:37:10 »
(Using the EZ-ADJ Menu)
PROCEDURE:
(1): Using Service Remote Press “ADJ” and enter password 0413 to open the “EZ ADJ” Menu.
(2): Select item 11 “White Balance” (Fig 1), If changing the Main board, write down the values (or use Cell phone Camera).
Enter these values into the replacement board. (Fig 2, 3 and 4). Note: These values will change model to model. They are
entered by the Factory according to the characteristic of the panel itself. Therefore they can vary even between models
using the same Panel.
(Note: If video can’t be seen on the defective board, use the “Pre-Loaded” data values that are already in the new
Replacement Main board.
