Автор Тема: 65EF9500 WebOS 2.0 OLED TV EDID SETTINGS  (Прочитано 1085 раз)
« : 25 Февраля 2017, 04:53:20 »
(Using the EZ-ADJ Menu)
SUBJECT: AC3 and PCM Audio issues:
1ST AUDIO ISSUE: LIP SYNC
On a Digital Stream there are three primary audio streams LG TVs can process. One is PCM (Stereo), another is
AC3 (Dolby®). Another is DTS® (Digital Theater System). When the stream audio is anything other than PCM there could be an issue with Lip Sync. This is where the Audio and Video are not synchronized.
Until the introduction of webOS 3.0 (explained later), the Factory’s EDID Software tells the processor to Ignore AC3 and DTS and only process PCM (If all streams are present). The Lip Sync adjustment only affects AC3 or DTS audio, (Digital Audio).
If the Channel being received is only providing PCM, then the TV has no choice but to process PCM audio.
The Lip Sync adjustment does not affect PCM audio. The Servicer/Customer has no way of telling what type of Audio stream is being processed on any channel without having additional equipment like having a high end audio processor that can display the Audio type that the system is processing.
If the Lip Sync adjustment just happens to be on a channel with AC3 or another source with DTS audio and there is a lip sync audio issues and an adjustment is made via the In-Start menu, the TV is “Fixed” into that delay parameter. If the customer moves or changes providers for their TV source, now the TV is incorrectly adjusted and will now require
another service call to fix the Lip Sync issue again. The customer must be made aware of this fact.
The Channel can have a lip sync issue only on one channel or at a specific program on a specific channel.
So Instead of adjusting the Lip Sync through the In-Start menu, the customer should adjust Lip Sync issues using the
Customer’s Settings Menu. “Sound”  “AV Sync Adj”  Turn “AV Sync Adj” to “ON”.
Then the Customer can select if they need to adjust the “Audio Delay” or “Bypass”. Audio can be adjusted for -5 (Audio
leads video) to +20 (Video leads Audio).
2ND AUDIO ISSUE: OPTICAL AUDIO OUTPUT: (Prior to webOS 2.0 / 3.0)
On a Digital Channel there are two audio streams LG TVs can process. One is PCM (Stereo) and the other is AC3 (Dolby®).
AC3 (Digital) is the only stream which can carry Surround Sound information. Of course now with webOS 2.0 and 3.0 we
have the inclusion of DTS and DTSHD stream processing.
