Автор Тема: 2014 (55EC9300) OLED SMPS Testing  (Прочитано 1086 раз)
« : 22 Февраля 2017, 08:17:12 »
Forcing on the Power Supply
Power Supply Testing
55EC9300
65EC9700
65” Note: This document is specifically designed around the 55EC9300. However, it can be used to
the 65” well Differences 65” connector same Published 06-16-2015
test 65 as well. are: 65 has 24 pin connector, but 1 through 18 are the as
55”. Main Board connector on the 65” is P2600 but the 55” it is P2300. Voltage chart on last page
may vary slightly between the two screen sizes.
TV Turn On Commands (Explained) 55EC9300 OLED (2014) Power Supply Section 05
(1) When AC is applied to the SMPS, it outputs 3.5V_ST to the Main board, P2300 pins 3, 5 and 6. This 3.5V is routed through
L2304 and on to the Microprocessor IC3000 pin 48 as its main power source. The 3.5V also goes to the Reset circuit. At the
moment 3.5V arrives at C3004 (+) side, the capacitor isn’t charged, so pin 40 of the Micro is low while the power input pin 48 is
high. This is known as the reset state, where the Microprocessor is reset to the first operational state. As C3004 charges
through R3030, pin 40 pulls up and the Micro comes out of Reset. The TV is now in the Stand-By state.
The 3.5V is also routed to pull-up resistors to the Key 1 and 2 lines. It is also sent to the IR receiver and as source voltage for
the Power on switch Q2300, but it is not on at this time.
(2) When the Power on key is pressed on the Joy Stick (Press in and hold), pin 31 of the Micro drops. This notifies the Micro that
the TV should turn on. If the Power On key on the Customer’s Remote is pressed, The IR receiver sends this signal (3.4V p/p)
to the Microprocessor pin 6 and the TV knows by this signal to turn on.
(3) The Micro outputs a low on pin 36 (RL_ON) which is routed to pin 2 of Q2300 turning it on. The 3.5V on pin 1 is then switched
out pin 3 and on to the SMPS via pin 1 of P2300. The Controller on the SMPS receives this command and turns on the 12V and
the 24V.
(4) The 12V and 24V lines are routed to the Main board via P2300, 24V pins 9, 10 and 16 and 12V pins 13, 14 and 15. The 24V is
used for the two Audio amplifiers as their amplification voltage.
(5) The 12V is routed to many different regulators (too many to mention here), but for this “Power On Cycle” discussion it goes
through coil L2303, then L12007, then L1401 and out P11401 pins 1-4 to the T-CON board.
(6) The 12V also routed to IC2307 (Power Detector). This IC then outputs a high to the Micro pin 14 to notify the Micro that the
voltage arrived. So the Micro can continue turning on the rest of the set. If missing, the TV will click on and then Click off. This
fault shows up in the Power Off Status as “5VMNT”.
(7) Once the Micro knows the 12V has arrived, it outputs a high on pin 15 which is routed to pin 1 of IC2300 turning it on. This IC is
the +3.3V_NORMAL regulator. This 3.3V is routed to many different circuits, but one of them is as a pull-up voltage through
R2310 to the INV_CTL (DRV_ON) line. However, the Micro is holding “INV_CTL” low via pin 19 at this time.
(8) The next step for the Micro to release the low on pin 19 and allow the “INV_CTL” line, (Inverter Control) to pull high,
(approximately 3.5V). This high leaves P2300 pin 2 and now becomes DRV_ON (Drive On). When this high arrives on the
SMPS controller IC, the controller turns on the Panel 24V line which is output P202 (pins 8-14) and on to the T-CON board
CN7. This voltage is then routed through the T-CON and out to the Panel itself for the Panel’s operational voltage.
NOTE: The Panel 24V is monitored by the Main board. There is a line on the Vx1 cable P11401 pin 20 called
MODULE 20V DET. This pin
2
MODULE_20V_line is normally 3.29V when the 24V is normal. If the 24V is missing or low, this line drops, pulling 44 of the Microprocessor low. Then the TV shuts off and logs “POWER_OFF_BY_20V_DET in the Power Off Status in INSTART
Menu.
