Автор Тема: 0IVL20151834  (Прочитано 740 раз)
0IVL20151834
« : 21 Февраля 2017, 17:56:05 »
Subject: LB65 series Case Top corrosion – Case top
* Bulletin Registration Date: 2014.10.16
* Effective from Date: 2014.10.16
Service Bulletin
TV
Bulletin Number:
* 3) Solution: (Short explanation of the solution)
-. Change the improved casetop
* Improved casetop verification method
- Light Silver Color : September 10 after producing casetop
- Carbon Titan Color : September 25 after producing casetop
1/5
* Applicable for models: (Customer models in alphabetical or numerical order per subsidiary)
*LB63/65 Series
General information
Technical information
Applicable in warranty: YES NO
Also applicable outside YES NO
of warranty:
Applicable only with symptoms YES NO
below:
Applicable with every repair: YES NO
•2) Problem / Cause: -. Surface defects due to rust.
•1) Symptoms / Customer Complaint:
-. Rust on casetop
* Applicable Serial Number: **LB65 Series
