Автор Тема: 0IVL20151757  (Прочитано 844 раз)
0IVL20151757
« : 21 Февраля 2017, 17:53:09 »
Subject: Replacement guide of EAJ62591001 (4 corner darkness issue included)
* Bulletin Registration Date: JAN 2015
* Effective from Date: JAN 2015
Service Bulletin
TV
Bulletin Number:
•3) Solution: 4 Corner darkness / This panel applied to the direct type LED arrays and minimum PKG quantity. ※ This symptom is not defect but in spec. ※ If the model Suffix name includes “W”: panel: EAJ62591001 may be used with fixers replaced (Left MJH63833901 /Right MJH63833902)
• If new panel must be replaced for other symptom(s): 1. order EAJ62591001 plus order and install new fixers (Left MJH63833901 /Right MJH63833902) -- (remove and discard existing fixers)
OR
2. order P/N AGF77999201 (Improved Module + Fixer Package)
--Remove and discard existing FIXERs; change to new FIXERs that come with new panel.
1/2
* Applicable for models: (Customer models in alphabetical or numerical order per subsidiary)
Check model full suffix of TV Set 4th character from right side should be “w”.
Ex)55LB670V-ZA.AEKWLJG
55LB67xx / 55LB68xx / 55LB69xx/
55LB70xx / 55LB72xx/
55LB73xx/ 55LB75xx /
55GB78xx
General information
Technical information
Applicable in warranty: YES NO
Also applicable outside YES NO
of warranty:
Applicable only with symptoms YES NO
below:
Applicable with every repair:
