Автор Тема: 10TV004  (Прочитано 1668 раз)
10TV004
« : 18 Февраля 2017, 11:11:30 »
EX-2L_Basil_Sat, EX-2L_Coriander_Sat, EX-2L_Paprika_Sat Chassis
No picture may appear, while the green LED is on.
CAUSE
Damaged NVM data on BA board.
Recover the TV set by applying the Software Recovering Tool using a Memory Stick.
1. Preparation – Memory Stick Requirements
• Remove unnecessary files from the MS before copying data.
• Use a Memory Stick formatter to format. Windows formatters are not supported.
• A format program can be downloaded from:
http://support.sony-europe.com/memstick/downloads/downloads_ms.asp?l=en&f=MSFRM#disc
• It is, however, recommended to use a Digital camera to format!
• After formatting, the content in the MS is just a “Memstick.ind” file.
• The flash size must be 16 MB or more.
2. Recovery procedure
2-1. In the Memory Stick, create a folder “eg2l_dvt” containing a subfolder “swupdate”.
2-2. Download the attached zip file, including the software recovery tool (RAM file) and NVM data (TAR file),
attached to this Technical Bulletin.
10TV004 - EX-2L - Software Recovery Tool for BA Board
« Последнее редактирование: 02 Декабря 2023, 00:20:24 от aze1959 »
