Автор Тема: Thomson 29DX25KG шасси ICC17 схема и инструкция по ремонту  (Прочитано 4934 раз)
схема и инструкция по ремонту Thomson 29DX25KG шасси ICC17
原理圖,示意圖
Schematic diagram
योजनाबद्ध आरेख
مخطط
Diagrama esquemático
Thomson 29DX25KG, Thomson 21DG22E, Thomson 21DK24E, Thomson 21DK24E1, Thomson 21DK24U, Thomson 21DP210G, Thomson 21DU21C, Thomson 21DU21E, Thomson 21DU22C, Thomson 21DU22E, Thomson 21DU24E, Thomson 21DX210S, Thomson 21DX25E, Thomson 21DX25EA, Thomson 21DX25ES, Thomson 21MT21E, Thomson 21MT22E, Thomson 24WK21E, Thomson 24WK22E, Thomson 24WK24E, Thomson 24WK25EG, Thomson 24WT25E, Thomson 25DG16E, Thomson 25DG16ET, Thomson 25DG17KG, Thomson 25DG21E, Thomson 25DG22E, Thomson 25DG25EG, Thomson 25DG25ES, Thomson 25DH21E, Thomson 25DH22E, Thomson 25DT21E, Thomson 25DT22E, Thomson 25DU21E, Thomson 25DU24E, Thomson 25DX210S, Thomson 25DX25ES, Thomson 25DX25KG, Thomson 25DX25KH, Thomson 25MH21E, Thomson 25MN16ET, Thomson 28DF21E, Thomson 28DF22E, Thomson 28DG16E, Thomson 28DG16ET, Thomson 28DG21E, Thomson 28DG22E, Thomson 28DG23K, Thomson 28DG24E, Thomson 28DK24E, Thomson 28DK25E, Thomson 28DK25ES, Thomson 28DK26ED, Thomson 28DN20E, Thomson 28DN22E, Thomson 28DP25EG, Thomson 28DP25ES, Thomson 28DT21E, Thomson 28DT22E, Thomson 28EX22E, Thomson 28VK24U, Thomson 28VK25E, Thomson 28VK25EG, Thomson 28VK25ES, Thomson 28VK26UW, Thomson 28WD210S, Thomson 28WF25E, Thomson 28WF25EG, Thomson 28WF25ES, Thomson 28WH200S, Thomson 28WN22E, Thomson 28WR23EG, Thomson 28WS21E, Thomson 28WS22E, Thomson 28WS24E, Thomson 28WS26EW, Thomson 28WT25ES, Thomson 28WT25ST, Thomson 28WX210S, Thomson 28WZ210S, Thomson 29DF25EB, Thomson 29DF25EG, Thomson 29DF25EL, Thomson 29DF25ER, Thomson 29DF25ES, Thomson 29DF25KG, Thomson 29DF25KH, Thomson 29DH21E, Thomson 29DH22E, Thomson 29DJ24E, Thomson 29DJ25EG, Thomson 29DL200G, Thomson 29DL21E, Thomson 29DL22C, Thomson 29DL22E, Thomson 29DL24E, Thomson 29DL25ED, Thomson 29DU21E, Thomson 29DU22E, Thomson 29DX210KH, Thomson 29DX210KP, Thomson 29DX210S, Thomson 29DX25ES, Thomson 29DZ210S, Thomson 29MH21E, Thomson 29MH22E, Thomson 32VK24U, Thomson 32VK25E, Thomson 32VK25EG, Thomson 32VK25ES, Thomson 32WF200G, Thomson 32WF25E, Thomson 32WF25EG, Thomson 32WF25ES, Thomson 32WH210S, Thomson 32WN22E, Thomson 32WS21E, Thomson 32WS23E, Thomson 32WS24E, Thomson 32WS26EW, Thomson 32WS26NW, Thomson 32WT210S, Thomson 32WX210S, Thomson 33MF22E, Thomson 33MF22EG, Thomson 33MS21E, Thomson 33MS24E, Thomson 33MS24EG, Thomson 33MS25UD.
Состав: процессор 92R195B9Q0/JAM, память 24C16 (SMD), ИП TS3702C, ИП BUW1215, TDA8139, видео TDA8855H, КР TDA8351, УНЧ TDA7269, стерео MSP34116 A2, тюнер CTF5510A, ТДКС 40330-68 (40330-66), HOT BUH516TH, ПК TDA6107JF.
« Последнее редактирование: 21 Июня 2017, 15:34:20 от aze1959 »
