Автор Тема: Philips 25ST1724 шасси GR2.2 AA схема  (Прочитано 1484 раз)
« : 20 Января 2017, 19:11:46 »
схема Philips 25ST1724 шасси GR2.2 AA
原理圖,示意圖
Schematic diagram
Diagrama esquemático
योजनाबद्ध आरेख
مخطط
Philips 25ST1724, Philips 213372SB, Philips 213842SB, Philips 213862SB, Philips 213962SB, Philips 213982SB, Philips 21GR2131, Philips 21GR2937, Philips 21PT440A, Philips 21PT442A, Philips 21PT520A, Philips 21PT522A, Philips 21PT530A, Philips 21PT532A, Philips 21PT570A, Philips 21ST2430, Philips 21ST2436, Philips 21ST2630, Philips 21ST2636, Philips 21ST2637, Philips 21ST2730, Philips 21ST2731, Philips 21ST2737, Philips 21ST2931, Philips 21ST2937, Philips 255251CB, Philips 255741CB, Philips 255831CB, Philips 255942SB, Philips 255962SB, Philips 256372SB, Philips 256392SB, Philips 256862SB, Philips 25GR9763/33, Philips 25MN1350, Philips 25MN1353, Philips 25MN1355, Philips 25MN1356, Philips 25MN1550, Philips 25MN1553, Philips 25PT400A, Philips 25PT400A, Philips 25PT405A, Philips 25PT410A, Philips 25PT430A, Philips 25PT440A, Philips 25PT442A, Philips 25PT450A, Philips 25PT451A, Philips 25PT452A, Philips 25PT470A, Philips 25PT470B, Philips 25PT472A, Philips 25PT480A, Philips 25PT480B, Philips 25PT480C, Philips 25PT481B, Philips 25PT482A, Philips 25PT490A, Philips 25PT492A, Philips 25PT510A, Philips 25PT510B, Philips 25PT512A, Philips 25PT512B, Philips 25PT520A, Philips 25PT521B, Philips 25PT522A, Philips 25PT530A, Philips 25PT532A, Philips 25PT540A, Philips 25PT542A, Philips 25PT570A, Philips 25PT570B, Philips 25ST2161, Philips 25ST2167, Philips 25ST2451, Philips 25ST2454, Philips 25ST2457, Philips 25ST2657, Philips 25ST2664, Philips 25ST2666, Philips 25ST2751, Philips 25ST2759, Philips 25ST2760, Philips 25ST2761, Philips 25ST2767, Philips 25ST2769, Philips 25ST2860, Philips 25ST2864, Philips 25ST2961, Philips 25ST2967, Philips 287231CB, Philips 287342SB, Philips 287942SB, Philips 287962SB, Philips 288372SB, Philips 288392SB, Philips 288572SB, Philips 288572SB/02B, Philips 288862SB, Philips 28MN1370, Philips 28MN1376, Philips 28MN1570, Philips 28PT400A, Philips 28PT400A/42, Philips 28PT405A, Philips 28PT410A, Philips 28PT440A, Philips 28PT442A, Philips 28PT450/42, Philips 28PT450A, Philips 28PT450A/00, Philips 28PT450A/42, Philips 28PT451A, Philips 28PT452A, Philips 28PT470A, Philips 28PT470B, Philips 28PT472A, Philips 28PT480A, Philips 28PT480B, Philips 28PT480C, Philips 28PT481B, Philips 28PT482A, Philips 28PT490A, Philips 28PT492A, Philips 28PT510A, Philips 28PT510B, Philips 28PT512A, Philips 28PT512B, Philips 28PT520A, Philips 28PT522A, Philips 28PT530A, Philips 28PT530A/00, Philips 28PT532A, Philips 28PT540A, Philips 28PT542A, Philips 28PT570A, Philips 28PT570B, Philips 28ST2181, Philips 28ST2181/10B, Philips 28ST2181/19B, Philips 28ST2187, Philips 28ST2281, Philips 28ST2281/10B, Philips 28ST2281/16B, Philips 28ST2287, Philips 28ST2287/19B, Philips 28ST2471, Philips 28ST2471/02B, Philips 28ST2471/08B, Philips 28ST2471/10B, Philips 28ST2471/12B, Philips 28ST2471/13B, Philips 28ST2471/16B, Philips 28ST2477, Philips 28ST2477/10B, Philips 28ST2477/42B, Philips 28ST2485, Philips 28ST2674/19B, Philips 28ST2686/19B, Philips 28ST2686/39B, Philips 28ST2687/19B, Philips 28ST2687/42B, Philips 28ST2761, Philips 28ST2771, Philips 28ST2780/08B, Philips 28ST2780/10B, Philips 28ST2780/13B, Philips 28ST2780/16B, Philips 28ST2781/02B, Philips 28ST2781/05B, Philips 28ST2781/08B, Philips 28ST2781/10B, Philips 28ST2781/13B, Philips 28ST2781/16B, Philips 28ST2781/22B, Philips 28ST2784/13B, Philips 28ST2785, Philips 28ST2786/10B, Philips 28ST2787/10B, Philips 28ST2787/42B, Philips 28ST2789/02Z, Philips 28ST2789/10Z, Philips 28ST2880/12B, Philips 28ST2884/12B, Philips 28ST2981/10B, Philips 28ST2981/16B, Philips 28ST2987/19B, Philips 52NA2304, Philips 52NA2307, Philips 52NA2317, Philips 52NA2364, Philips 52NA2366, Philips 52NA2376, Philips 52NA2377, Philips 52TA4310, Philips 52TA5210, Philips 52TA5211, Philips 52TB4290, Philips 52TB5190, Philips 52TB5191, Philips 62CA1563, Philips 63CA1503, Philips 63CA1505, Philips 63CA1513, Philips 63CA1515, Philips 63CA1563, Philips 63CA1573, Philips 63CA1595, Philips 63NA2514, Philips 63NA2517, Philips 63NA2574, Philips 63NA2576, Philips 63NA2607, Philips 63NA2617, Philips 63NA2618, Philips 63NA2666, Philips 63NA2676, Philips 63NA2677, Philips 63TA3910, Philips 63TA3960, Philips 63TA4010, Philips 63TA4110, Philips 63TA4310, Philips 63TA4410, Philips 63TA4411, Philips 63TA4610, Philips 63TA4611, Philips 63TA5210, Philips 63TA5211, Philips 63TB3890, Philips 63TB4390, Philips 63TB4391, Philips 63TB4590, Philips 63TB4591, Philips 63TB5190, Philips 63TB5191, Philips 70CA1703, Philips 70CA1705, Philips 70CA1763, Philips 70NA2714, Philips 70NA2717, Philips 70NA2774, Philips 70NA2776, Philips 70NA2807, Philips 70NA2808, Philips 70NA2817, Philips 70NA2818, Philips 70NA2819, Philips 70NA2866, Philips 70NA2876, Philips 70NA2877, Philips 70NA2879, Philips 70TA3910, Philips 70TA3960, Philips 70TA4010, Philips 70TA4310, Philips 70TA4410, Philips 70TA4411, Philips 70TA4610, Philips 70TA4611, Philips 70TA5210, Philips 70TA5211, Philips 70TB3890, Philips 70TB4390, Philips 70TB4391, Philips 70TB4590, Philips 70TB4591, Philips 70TB5190, Philips 70TB5191, Philips M7229.
Состав: процессор TMP47C1637N-U216, ИП CNR50, ИП BUT12AF, TDA4661, TDA4680, TDA4565, TDA4510, TDA3857, TDA8417, TDA8425, TDA2579B, SAA5246A, тюнер UV916, ТДКС 37992, HOT BU508A.
« Последнее редактирование: 24 Июля 2017, 05:46:24 от aze1959 »
