Автор Тема: LV-129  (Прочитано 793 раз)
LV-129
« : 16 Января 2017, 11:53:47 »
We would like to inform you of service information for the models below.
Model LC-20B5E, LC-15B5E
Phenomenon Unit does not find the channel E-7(189.25MHz). It can be found by moving frequency to
189.20MHz or 189.30MHz.
Cause IC2 data communication error
Servicing In this case, please change the value of two resistors on ANALOG UNIT.
1. Change the value of R3201 from 4.7K Ω (VRS-CY1JF472JY) to 10K Ω (VRS-CJ1JF103JY).
2. Change the value of R2235 from 100 Ω (VRS-CY1JF101JY) to 0 Ω (VRS-CJ1JF000JY).
