Автор Тема: E35003456  (Прочитано 819 раз)
E35003456
« : 08 Сентября 2016, 09:53:24 »
E35003456
Event ID
E35003456   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
8/20/2007 7:43:39 PM
Subject
Backlight adjustment not working
Backlight adjustment not working.
Back light adjustment not working.
Display bar is moving but backlight is not changing.
[Primary Symptom Code: 118X ]
Solution
Backlight adj was working after reset was performed.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
And/or serial number.
Model Details
KDL32S20L1    SEE    SOLUTION    STE   5/1/2006   WAX2   40   TV and Display (TVP)
KDL40S20L1    8051159    8051159    STE   5/1/2006   WAX2   40   TV and Display (TVP)
