Автор Тема: E34777024  (Прочитано 800 раз)
E34777024
« : 08 Сентября 2016, 09:52:51 »
E34777024
Event ID
E34777024   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
5/1/2009 2:01:03 PM
Subject
Change data when replacing the FB board
Are there any data settings required when changing circuit boards on these models?
[Primary Symptom Code: 118X ]
Solution
Yes. Whenever you change an FB1 or FB 3 board you need to make sure that the PANEL
SIZE bit is set correct.
NOTE: Before changing the FB Board refer to SB E35994728 (Board P/N depends on panel
used.)
While the TV is in STAND BY enter the service menu by pressing the following key sequence
within 5 seconds:
DISPLAY, CH 5, VOL +, POWER ON
Once in service mode:
Press the JUMP button 3-times to reach the BEM micro.
Then press the 2 button 2-times to reach the Model Info category.
The first item is Panel Size. Use button 3 or 6 to set the data for the correct panel size:
Item : 0002 Model_Info / 0001 Panel_Size
Data : 40inch 0, 46inch 1, 52inch 2
Once you select the correct screen size press MUTE, 0 to write the data.
Cycle power on TV to exit the service menu.
Supporting Documents
File   Description
Service_Adj.pdf   Service Adjustment Procedure
Model Details
KDL40V3000    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL40VL130    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL40W3000    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL40XBR4    ALL    ALL    STE   8/1/2007   FIX2   40   TV and Display (TVP)
KDL40XBR5    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL46V3000    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL46VL130    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL46W3000    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL46XBR4    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL46XBR5    ALL    ALL    STE   7/1/2007   FIX2   40   TV and Display (TVP)
KDL52W3000    ALL    ALL    SRE   8/1/2007   FIX2   40   TV and Display (TVP)
KDL52WL130    ALL    ALL    STE   8/1/2007   FIX2   40   TV and Display (TVP)
KDL52WL135    ALL    ALL    STE   8/1/2007   FIX2   40   TV and Display (TVP)
KDL52XBR4    ALL    ALL    STE   8/1/2007   FIX2   40   TV and Display (TVP)
KDL52XBR5    ALL    ALL    STE   8/1/2007   FIX2   40   TV and Display (TVP)
